Guest viewing is limited
View the thread, titled "Plastic CU EICR code?!" which is posted in Periodic Inspection Reporting & Certification on Electricians Forums.
Hi everyone
I am in two minds on how to code this on an EICR recently completed.
Plastic CU under-stairs and under 150mm to gas meter with a tiny bit of firer retarded board between.
By looking through regs I've come to C3 but I'm extremely nervous about it.. C2?
Any feedback appreciated. Thanks
Georgie.
C3, not to current standards. A plastic unit is no more likely to burst into flames than a ferrous one, especially so if the last one to work on it was skilled and diligent enough to tighten check everything before popping the lid on, even if such concepts are outdated.
My 'agree' applies to the second sentence above, more so than the first, although definitely C3.
C3 if Consumer Unit is still in good condition.
My only concern would be the barrier it is a bit of a token effort!
My understanding is the minimum distance is 150mm and where that isn't achieved then a suitable non conductive barrier should be installed. Got this from BS6891 8.4.2.1 which is referenced from the NOTE under regulation 528.3.4 in the Regs.
The barrier in my opinion isn't providing the required separation to the top half of those gas pipes.
I
I
A wooden consumer unit would almost be as fresh as the day it was installed in 1958 .I think that's when we made things in this country as appose to cheap junk made in other countries which I won't mention. A plastic consumer unit under wooden staircase c3
Reply to the thread, titled "Plastic CU EICR code?!" which is posted in Periodic Inspection Reporting & Certification on Electricians Forums.
