Gets more complicated with wet rooms. Zones 0 and 1 are determined by a 1200mm radius with its centre directly below the water outlet of the shower. If there is a fixed partition as well, then this 1200mm radius ends when it is outside of the partition and at right angles to it. From there you continue on with a radius determined by this formula: (1200 - y - s) mm, where y is the distance from the centre of the 1200mm radius to the inner edge of the partition and s is the thickness of the partition itself. The centre of this radius is the outer corner of the partition.
The regs. make no mention of zone 2 when these formulae are used, so it goes abruptly from a combined zones 0 and 1 to outside the zones.
