L
Luchador
Hey there,
Have any of you fellas got experience of working with Accenta 6 alarms? Went to a customer today who has one of these alarms and he doesn't know his user code (recent change of occupancy). I checked on the internet whilst there for a manual / instructions and found one which I thought was for this model but when looking at the reset instructions they explained that, amongst other things, a wire from the SET terminal on the control panel needed to be removed but there was no wire in it to remove! The alarm had worked prior to the user code being forgotten though. Does anyone know how to go about resetting the user code? Any help would be greatly appreciated :)
If you have the installation manual you will find it is in there, as as far as I can remember it does have something to do with linking the set terminal.
think you power it down. link set+ to PA, then power up. may have to repeat. user code will then be 0123, but al other programming will be lost. i'm going out in 5, but will try and confirm later. might be an idea to try 0123 before trying resetting.
They normally use "jumpers" on the board... You know like you get in computers.. Well you did in my day.
Look for a jumper marked SET
There wasn't one unfortunately RWJ.
This is what it says in the manual:
Defaulting User Code 1 and Engineer Code
1. Power down panel.
2. Remove wiring from SET output and TAMP input (next to PA).
3. Fit shorting wire between SET and left-hand TAMP terminal.
4. Power up.
5. Wait for alarm to start.
6. Power down panel and then restore original wiring.
There was no wire to remove from SET output but I did everything else and it didn't do the trick unfortunately. I was hoping there may be an alternate way of doing it without having to incorporate SET.
I tried 0123 too, I had no joy with that either sadly.
4. Power up.
Did you try fitting a wire between SET and left hand tamper?? then powering up??
Aye, I tried that RWJ. Sparky 3366 is probably right about being careful about sharing this on an open forum. If you guys would prefer to PM me that's fine. Thanks.
all this stuff is public knowledge since it is in the manual, it should work when you link out the set and tamp terminations, just get a new panel they are so cheap will be cheaper than fannying about i would think
you must remove the wires from the tamper pair of terminals first . then link set+ to L/H tamper terminal.then power up.wait for alarm to sound, then power down, remove link and power up again. sometimes you have to do it twice.
Aye, I think that's the way to go morph to be honest. Does it have to be like for like when it comes to a new panel i.e. Accenta 6? Or will any Accenta model be compatible?
As the manual has already been quoted, and it is not possible to perform this reset without triggering the alarm in any event.....
The manual assumes that the original installer has utilised the remote set button facility on the panel. So to perform a reset, any wiring that exists here must be first disconnected.
It can be a bit awkward, especially under pressure with the panel and all the sounders going off whilst you are doing it.
What exactly needs to be disconnected then BlueToBits?
Accenta 6 Alarm: Lost user code
Luchador,
paulsanderson,
