An Awful Feeling This
Hi Mate
here are some things to help your remember stuff
Periodic inspection you are looking for a SADCOW. issues of Safety. Ageing, Deterioration. Corrosion, Overloading, Wear and Tear.
Also Insulation resistance is like a teabag the longer the cable the more perferations so more area to leak out of hence Insulation resistance decreases with length.
Cable resistance is like linking sausages togethr the longer the length the more sausages you have so greater resistance
Also learn the proper terminology for protective conductors. See little map at end of appdx 2
Circuit protective conductors connect to exposed conductive parts to MET. Exposed parts of electrical equpt motors lights etc
Main protective bonding connects gas and water Extraneoues conductive parts to MET. Any EXTRA METAL is Extraneous
Earthing conductor connected between MET and earth electrode
Hope this helps
Think you mean section 2---------Definitions
Sorry to say passed first time mate but what i would say is i know a lot of bright guys who are in the same position as you.
Apart from the obvious hammering the passed papers how you approach the exam is vital. I.e. Alot of people get caught up with the low value questions at the start and spend to much time on them leaving insufficient time for the high value questions.
you know the help and advice i have been given in this thread is amazing, you know i have worked with sparks over the years that would not give you the time of day/or they are rubbish and you would not ask them to wire a dog kennel for you.
Some people on this site have really helped me and been really patient.
Thanks for all your help, i prob learnt more from here than the books lol
Personally I wouldn't put yourself under too much pressure end of the day you can always resit! Just forget about the past exams if u get nervous before try taking a pill for travel sickness it might sound silly but I know a few who take them before exams, Uni etc and say it helps, maybe a mind thing but worth a shot. Read all questions carefully and use right definitions.
I did in mine during my fourth year apprenticeship while all the college stuff was still in my head and even then it was hard, goodness knows who the guys who where out of college for years managed it but persevre and you'll get there in the end. GOOD LUCK
Go for the higher value questions first...its where the points are.........
You beauty!!​
:hurray::hurray::hurray::hurray::hurray:
A big thumbs up to all on here for being so awesome.
gap30,
trev,
