Square D QOE style MCBs.
View the thread, titled "Square D QOE style MCBs." which is posted in Australia on Electricians Forums.
Amp David
Mentor
Can anyone tell me if the different generations of QOE MCBs are compatible.
Need to replace an MCB with an RCBO, and can only get a newer style RCBO that has been guaranteed to work properly
you need to contact square d. as far as i know, the later ones will not fit the older boards. i've been stung with a 3 phase QO MCB at £100.
From memory the newer mcbs & rcbos (the ones that screwfix & toolstation sell)are not compatable with the older quickine boards so best to try a wholesalers if I can remember rightly they have plug in connection to the buzz bar and some are at the top and the other at the bottom.
I had the same problem and had to order some through one of the wholesalers,
nope - deffo dont fit mate. Also, you will be looking at well over £120 quid for an RCBO. i have a job going at the min where i am going to have remove the QOE board simply cos i cant get the blanks for it! Sq D are good, but they take the mick a bit when they change their models, then have you eyes out for the older ones!
There is nothing Good about the older Sq D, Fed Elect, GE, plug-in breakers and boards, they were and always have been American Crap with a capital C!! lol!!
Reply to the thread, titled "Square D QOE style MCBs." which is posted in Australia on Electricians Forums.
