Armeg Sheet Steel Hole Saws | on ElectriciansForums
Discuss Armeg Sheet Steel Hole Saws in the Electrical Tools and Products area at ElectriciansForums.net
Market Harborough
Hi,
I am going to buy a set of these, below, you can get a set of three, 20mm, 25mm and 32mm I think it was.
I had a go with them in Eddies the other day as the Armeg bloke was there, I have to say I was very impressed with them.
Acceler8% Sheet Steel Holesaws
What do you use and do you think they are worth buying?
Never used the Armeg ones, I have used/owned Starret, Bosch, CK and Eclipse ones, and these are pretty much of a muchness quality wise, I noticed a friend of mine had some Ebaur (screwfix) ones which are much cheaper than mine but looked ok, I will ask him how he got on with them when I next see him.
I see these in the wholesaler the other day (not my normal wholesalers) I think it was ÂŁ55 for the 3 piece set which I thought was a bit pricey. What did you get quoted?
We use punches in the workshop, they're quicker and neater as Rob says, also no worries about swarf in MCB's and contactors etc. Holesaws I prefer the cheaper short preassembled short ones for the smaller sizes, saves messing around changing the mandrill around and they last a month or two and we just replace them. The sizes 40mm - 150mm are Starret.
I've been using Armeg hole saws for about a year now, pretty good. The spring will break before the teeth do and dont believe their 3.4s advertising, it is not that fast.
These are the disposable type we use in small sizes up to 32mm.
[ElectriciansForums.net] Armeg Sheet Steel Hole Saws
I had a go with them in some steel, yeah they seem good, just wondered really, they seemed good but not sure if I would use them much that's all.
How do you go about making a hole in steel trunking that's already fixed in place then? Presumably the punch is quite a stationery tool unlike the drill bit?
You still have to drill a hole, 8-12mm dependent on the size of punch. Standard drill bits can be used. In the workshop we have a hydraulic punch. If I'm out on site I've got some that will work with my impact gun, or an Allen key.
They em are a godsend for work with stainless steel.
They are good for trunking work, I treat them as consumables and just buy a new set before starting a trunking job.
The hole punches are brilliant for trunking which is already installed as they cut down the amount of swarf etc. Look up Q max hole punches
Reply to Armeg Sheet Steel Hole Saws in the Electrical Tools and Products area at ElectriciansForums.net
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
