Armeg Sheet Steel Hole Saws | Page 4 | on ElectriciansForums
Discuss Armeg Sheet Steel Hole Saws in the Electrical Tools and Products area at ElectriciansForums.net
On the subject of fixings (hope I'm not off topic) I use fixings in concrete that just require a pilot hole, then are put in by the Impact Wrench, though I can't remember what they're called. They are quicker than the usual wedge anchors, though more costly, and don't require the carrying of any setting tool.
these?
[ElectriciansForums.net] Armeg Sheet Steel Hole Saws
Thunderbolts them would be :)
I'd be very cautious of using any kind of impact equipment to fit these, the key part of its strength is 1 spiral thread and it creates its own groove, any damage to this cut groove can seriously impair the fixing strength of the bolt.
Another vote for punches I carry a set from 16 to 50 mm cost me £60 had them for 7 years so I would argue they are cheaper than buying holesaws,
however they're only suitable for thin metal !
Re holesaws I use starrett with a quick change arbor I got from cef a few years ago.
Also Imo impact drivers have their place , but I find people use them on threads unsuitable for this method and if it's something which might need to be undone can be a problem .
The quick release arbor I use is an older version of this
"Morse fast adapt QR"
it has small attachments you fit on the holesaws and you just twist the base of the arbor to release take of one size to swap with another, takes literally a couple of seconds!
Also have attachments to allow two holesaws to be fitted to allow opening up of holes drilled ie 20 to 25 mm
Excellent bit of kit definitely recommend! had this set for 5 years, no issues and got me out of trouble once or twice
Reply to Armeg Sheet Steel Hole Saws in the Electrical Tools and Products area at ElectriciansForums.net
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes...
