Dodgy trade pictures for your amusement! - 1 Million Views! | Page 49 | on ElectriciansForums
Darkwood
It all coming out. The rest of the farms in just as much of a mess, we have only just done a condition report.Idealey hell have the supply upgrade to 3 phase the we will go from there, but he's not to keen as electric board cost are rather substantial.
Would appreciate any surgestion if I can't get him to upgrade.
quote Tony Barnes "It all coming out. The rest of the farms in just as much of a mess, we have only just done a condition report.Idealey hell have the supply upgrade to 3 phase the we will go from there, but he's not to keen as electric board cost are rather substantial.
Would appreciate any surgestion if I can't get him to upgrade."
Looks like a split phase supply from an overhead line voltage between the 2 phases will probably be 480v.
Check voltage between the "phases" to confirm .
L1 to N+L2 to N = L1 to L2 its split phase and will be 480v (some 3 phase boards are only rated for 400- 415v)
Split phase is fed from a centre tapped transformer and conversion by the DNO will be cost prohibitive unless you get a few customers together.
I believe MEM used to make a split phase board but not now, we could not find any DB with a rating higher than 415V last year, in the end we used MEM Exel Switches/ switch fuses which are rated 550V for the 480V bits, feeding single phase boards.
    • Friendly
