Dodgy trade pictures for your amusement! - 1 Million Views! | Page 50 | on ElectriciansForums
Darkwood
Found during a T+I yesterday, extensions into a new 3ph DB. There is so much wrong in this photo, but most of the terminals are 2.5mm size, the conductors in the bottom are 4mm, some terminals have 2 conductors jammed in, heatshrink has been used to cover crimps but has been held in place with tape, there is 16mm in one end of the crimp and 10mm in the other, the blue conductors are tri-rated singles and are not fitted with ferrules,there is no top to the DB and so on.
This is the first this DB has been inspected, it was fitted last year There are other problems in the DB itself with poor supply cable terminations, unsupported cables, undersized main earth conductor, grossly incorrect circuit labels, no RCD protection on any circuits, missing blanks, neutral and earth conductors incorrectly numbered... Yes we will be correcting the problems. The installation has a 2000A supply and around 90 DBs. We've started testing/inspecting a part of the installation, testing and repairs will continue in stages to the other parts over the next 4 years.
Oh dear! Is that box/rail earthed?
Heat shrink held in place with tape? lol! Not even the right coloured tape. Is that main earth joined under the tape as well?
Needs some grommet strip round that top as well
Think you're gonna be in that place for a while if the other 89 DB's are nearly as bad
Keep up the good work
PS
Bet that fcu was a bit smelly....
Bloody plumbers! Ripped this wiring out on Thursday, some of the worst heating system wiring I've ever seen. Look closely and you can see why. It's a good job the pipework was all copper with main bonding as the heating electrics had no earth connection. Some cpcs had been cut out and used for switched lines, even though spare insulated conductors were available. Total madness. The joint box was jammed behind some pipes in the airing cupboard. The supply was all wrong as well, fed from a SFCU the incoming and outgoing neutrals were in the same terminal, wired in .75 flex connected to a 30A 3036 fuse.
Does the artex covering help prevent any fire spreading?
