Hi, I'm at a job where there is 4x16 amp sockets protected by 4x16 amp rcbos in a bollard, the customer now wants 6 amp rcbos cause he wants to limit what people are using can you do this? I suppose it will just trip if people use more than 6 amps
Discuss 16 amp socket help please in the UK Electrical Forum area at ElectriciansForums.net
What a load of bollardsHi, I'm at a job where there is 4x16 amp sockets protected by 4x16 amp rcbos in a bollard, the customer now wants 6 amp rcbos cause he wants to limit what people are using can you do this? I suppose it will just trip if people use more than 6 amps
What is being used that the owner wants to limit the use of ?
electricity?
Blimey that pic kicks my attempt at humor into touch, I honestly thought you had spelt boards as bollards, oh well never mind eh.These are the bollards, and thanks guys much appreciated
Yeah ok I should have said what types and sizes of appliances ...
You'd think after all my time on here and years of wading through City and Guild's ambiguous syntax, I would have learned to construct a concise and specifically worded sentence wouldn't you ?
No just general power to a boar yardOkay, stupid question time.
Is this installation designed to supply something like a market stall? The reason I ask is because I see C type RCBOs have been fitted.
No but we do a lot of work within caravan siteslooking at the back ground in that picture is a caravan site !
Easy mistake lolFair enough, I just saw decking. I shall have a read of Section 721, then...
Assume that you mean a boat yard. Fitting 6A MCBs will stop the use of some power tools. Is that really what your customer wants?No just general power to a boar yard
Reply to 16 amp socket help please in the UK Electrical Forum area at ElectriciansForums.net
