Question about earth wire - photo attached | on ElectriciansForums
Discuss Question about earth wire - photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
UK
An electrician noticed that the clamp on the earth wire in my house wasn't right while he was fixing an unrelated fault. He called the power company because they have a legal duty to fix it. I noticed that the guys from the power company have used tape instead of a clamp and wondered if this is acceptable?
Thanks.
[ElectriciansForums.net] Question about earth wire - photo attached
There could well be a clamp under the tape or as above it's been sweated on
Also....get that earthing conductor checked pronto! Earth fault current will be unsure where to go and won't know it is allowed to flow through it as it's splendid green/yellow markings have been painted over in emulsion.
Don't actually know but are supplied in some jointing kits. I don't reckon there is one under there it is too bulky on one side. Wouldn't mind a pic from a couple of other angles.
Could the bulk be where the braid has been folded over to prevent it from being pulled out?
Used them in jointing kits and they seem ok, but that doesn't look they've scraped the crap off to make a good connection, i'd certainly investigate o_O
Are they not a CP clip? as in "constant pressure"?
As mentioned,i think they were in part designed,to remove some of the risk/skill:rolleyes: from a proper sweating job.
But i have seen everything from jubilee clips to a child's tool bench vice,used...
Yes basically, CV joint is actually constant (angular) velocity which is a special kind of universal joint that is basically smooth regardless of the angle or turn, used in car driveshafts
...And as a little extra,the balls out of a CV joint,make devastating ammo,for a high-powered catapult :)
Reply to Question about earth wire - photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
Then you've been lucky. I've encountered it many times in my 20 years of doing this professionally and I'm sure the 100's of years of combined...
davesparks
I see that point . I’m going to have to run a new cable into the meter then at my cost. more than likely as I’ve finished the job now
A crimping tool that is designed for copper terminals, may well not put enough pressure on the terminal to hold the cable correctly if used with...
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
