Question about earth wire - photo attached | Page 2 | on ElectriciansForums
Discuss Question about earth wire - photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Don't actually know but are supplied in some jointing kits. I don't reckon there is one under there it is too bulky on one side. Wouldn't mind a pic from a couple of other angles.
Used them in jointing kits and they seem ok, but that doesn't look they've scraped the crap off to make a good connection, i'd certainly investigate o_O
Are they not a CP clip? as in "constant pressure"?
As mentioned,i think they were in part designed,to remove some of the risk/skill:rolleyes: from a proper sweating job.
But i have seen everything from jubilee clips to a child's tool bench vice,used...
Yes basically, CV joint is actually constant (angular) velocity which is a special kind of universal joint that is basically smooth regardless of the angle or turn, used in car driveshafts
...And as a little extra,the balls out of a CV joint,make devastating ammo,for a high-powered catapult :)
Reply to Question about earth wire - photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I opened up the CU again and the round junction box above and what I found was the blue and brown wires coming in from the wall just above the 15a...
2 3
Thank you so much for your help with this light work perfect now thank you again much appreciated
