Thanks chaps, got some choices I'm liking the S&P/Envirovent ones. Guess I'll just have to skip the part in the instructions about having an isolator with 3mm contact gap... that would be the main switch in the CU
Discuss Extractor fans that don't need a fuse in the Electrical Tools and Products area at ElectriciansForums.net
Soldered in - I guess they're thinking if the internal fuse blows it's kaputHard to see but is the fuse soldered onto the pcb or is it replaceable ?
Shouldn't be a problem, as fan isolators should meet this. Anything with the symbol nicely shown on the pic will be ok, so will plenty of others. It may be possible to find a 3 pole fan isolator for sale that doesn't meet the standards listed in Table 537.4 , but I hope not.... Guess I'll just have to skip the part in the instructions about having an isolator with 3mm contact gap...
Hi TJ - these are made as 2 separate units, so you can bring unswitched L to the fuse then take Lfused to the fan (via one isolator pole), another Lfused to the light switch and back to fan (via next isolator pole) to give Ls and N (via 3rd pole) as usual. Ha - where's a good drawing?
Thinks those only fuse the permanent line though?......Another thing is you can get a fuse incorporated with the 3 pole switch too. A lot neater and cheaper thsn fitting an ectra fcu. Click do them..
Probably right..Thinks those only fuse the permanent line though?......
Reply to Extractor fans that don't need a fuse in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
