Extractor fans that don't need a fuse | Page 3 | on ElectriciansForums
Discuss Extractor fans that don't need a fuse in the Electrical Tools and Products area at ElectriciansForums.net
Thinks those only fuse the permanent line though?......
Is that correct? I don't know.
I may be wrong but, without testing, something tells me it could be dangerous......the fan doesn't run on yet the unit is still live with the switch in 'on' position.
In other words, the fuse isn't fully isolating the unit.
No, if switched off the there is nothing live on the fan/load supply side, just like a DP switch. Only line is fused and isolated by the switch when you wire one - as per the diagram manufacturers usually supply with their fan instructions
Reply to Extractor fans that don't need a fuse in the Electrical Tools and Products area at ElectriciansForums.net
Which begs the question, where does the second brown wire come from?
I've been asked to replace an Xpelair CF20 extractor fan which has been recessed into the ceiling. I've had a rummage and managed to find a CF20TX...
