Extractor fans that don't need a fuse | Page 2 | on ElectriciansForums
Discuss Extractor fans that don't need a fuse in the Electrical Tools and Products area at ElectriciansForums.net
Thanks chaps, got some choices :) I'm liking the S&P/Envirovent ones. Guess I'll just have to skip the part in the instructions about having an isolator with 3mm contact gap... that would be the main switch in the CU ;)
... Guess I'll just have to skip the part in the instructions about having an isolator with 3mm contact gap... ;)
Shouldn't be a problem, as fan isolators should meet this. Anything with the symbol nicely shown on the pic will be ok, so will plenty of others. It may be possible to find a 3 pole fan isolator for sale that doesn't meet the standards listed in Table 537.4 , but I hope not.
[ElectriciansForums.net] Extractor fans that don't need a fuse
Hi TJ - these are made as 2 separate units, so you can bring unswitched L to the fuse then take Lfused to the fan (via one isolator pole), another Lfused to the light switch and back to fan (via next isolator pole) to give Ls and N (via 3rd pole) as usual. Ha - where's a good drawing?
Ah...I see :). Only good for new install then or otherwise making wiring changes to accommodate it.
I know they're pricier but S& P are good fans. Quiet and superior extraction on 4 inch vent. 5 inch ones not cost much more for twice the extraction rate too..
I always tend to fit these as first choice now..
Reply to Extractor fans that don't need a fuse in the Electrical Tools and Products area at ElectriciansForums.net
Which begs the question, where does the second brown wire come from?
I've been asked to replace an Xpelair CF20 extractor fan which has been recessed into the ceiling. I've had a rummage and managed to find a CF20TX...
