Are these wires neutral? | on ElectriciansForums
Discuss Are these wires neutral? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Rayleigh
I'm currently in the process of running neutral wires around my house to all the light switches so that i can install some of these new wifi smart switches to control all of my lighting.
One of my light switches has a black and a blue wire connected together separately from the switch shown in the attached photo.
How can i tell for sure if they are neutrals?
[ElectriciansForums.net] Are these wires neutral?
Dug out an old multimeter with longer wires to test the continuity between the switch and the light. Turns out they are neutral.
Win for me as i don't have to run a neutral to this switch now!
I'm curious on how you are going to run Neutrals everywhere.
(without ripping your house apart! :))
All the switches are on stud walls. Downstairs are close to the landing which I'm waiting to carpet and then upstairs I'm going to try running them down from the loft. Will be interesting to see if it is possible or not.
Interesting, there also seems to be a lack of twin brown from what I've gathered on here
Can get twin brown in Scotland ok but most of the wholesalers round my way need a few days notice to get it as it isn’t often used. Usually when you ask for it you get normal t&e and a lump of brown sleeving.
And here it's unheard of to wire switch drops in brown & blue.
Im confused, you had zero volts from the perm live at your switch to your suspected neutrals at the switch, but continuity from the suspected neutrals at the switch to neutrals at your light? or were you testing from an unenergised switched live? hence no voltage at the switch!!!
I was given a couple of rolls of sheathed & insulated single red & black and of sheathed & insulated single & earth a few years ago, virtually unused. They prove very handy from time to time - with the appropriate sleeving at the terminations, naturally...
Reply to Are these wires neutral? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You were correct those are neutral wires, it worked! Many thanks
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
If any appliance has a filter or surge protection device, you will have a device that can pass a small current between the L and E or the N and E...
That doesn't look a very big cable for the supply to a property. Could it be a 3 phase supply, in which case they'd be a bit more of a suitable...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
