Are these wires neutral? | Page 2 | on ElectriciansForums
Discuss Are these wires neutral? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's an off-the-shelf item here at wholesalers, though from what I gather is extremely uncommon in England.
I actually thought it was on the shelf everywhere what do you do in England when you require it?
Interesting, there also seems to be a lack of twin brown from what I've gathered on here
Can get twin brown in Scotland ok but most of the wholesalers round my way need a few days notice to get it as it isn’t often used. Usually when you ask for it you get normal t&e and a lump of brown sleeving.
And here it's unheard of to wire switch drops in brown & blue.
Im confused, you had zero volts from the perm live at your switch to your suspected neutrals at the switch, but continuity from the suspected neutrals at the switch to neutrals at your light? or were you testing from an unenergised switched live? hence no voltage at the switch!!!
I was given a couple of rolls of sheathed & insulated single red & black and of sheathed & insulated single & earth a few years ago, virtually unused. They prove very handy from time to time - with the appropriate sleeving at the terminations, naturally...
And the first time I came across twin brown I asked a customer to pop to Poofix on a weekend to get 100m 1.5 T&E and they returned with 2x 50m reels “as it worked out a lot cheaper” - because it was twin brown! That made the feed on the lighting circuit interesting....
The last train brown I collected (yesterday) the wholesalers said "there's your 2.5 masquerading as a bit of twin brown" :)
For those unaware Irish Standard 201 cable has a full-sized and insulated cpc which gives the cable the appearance of the next cable size up for British Standard cable. (I stock both Irish Standard and British Standard cable.
Reply to Are these wires neutral? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You were correct those are neutral wires, it worked! Many thanks
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
