2 way switches not working | on ElectriciansForums
Guest viewing is limited
Discuss 2 way switches not working in the UK Electrical Forum area at ElectriciansForums.net
Loky11
North yorkshire
Now guys,
Need some help please, i have a 2 way switch that not working correctly, got a 2 gang 2 way switch on landing of 1st floor, on second floor there's a 1 gang 2 way switch, now the problem is that if the light is turned on from 1st floor it can not be turned off from 2nd floor and vice versa, it will only turn off from the switch that turned it on. Is it possible that the wires in the switches arnt wires in the correct terminals ? All advise appreciated. Cheers.
Now guys,
Take a pic of both and post them up.
I have a pic of the 1st floor switch (will upload in a min), dont have one of 2nd floor switch tho but its only a 1 gang switch which had red in common, blue in 2 way ( which im guessing is the same as L2) and yellow in 1 way (same as L1?)
In first pic its the red wire on left and the yellow and blue on right which is the switch in question.
[ElectriciansForums.net] 2 way switches not working
Without knowing how the other switches are wired up, it looks like the two reds have been swapped?
You might need an electricians services to sort this, as being the stair lights, those two switches could be on different circuits
The switch in the pics is on 1st floor which left switch turns first floor on/off also has a 2 way switch on ground floor which also turns 1st floor on/off this works as it should. The right switch turns 2nd floor (top floor) on/off. However this doesnt work as it should. The lamp on 2nd floor only had live, neutral and earth going to it.
Sounds like there is a hidden junction box somewhere. If it was wired as a three plate system you would have another two core at one of the switches. If the second floor light has only one cable connected then there are other hidden connections.
Yes mate the switch on 2nd floor is a 1 gang 2 way but only has 1 cable going to it (twin+earth) then only a live, neutral and earth to the ceiling rose(2nd floor) there is a junction box underfloor boards on 1st floor below the light switch. Not sure if theres any on 2nd floor.
Somewhere there is definitely another connection because from what you have is just an apparent cable between the switches, there must be something inbetween.
Definitely need a picture of the 2nd floor switch.
If it worked before then it's just 2 wires crossed in the 2nd floor switch, but if there's only a twin at the 2 way it doesn't add up
My bad mate, on 2nd floor its 3 core and earth, i do apologise red in common yellow in L1 and blue in L2 and obv earthed. I think the blue wire on 2md floor switch is switced live because when i put a non contact detector on it it turned live when swirched.
Reply to 2 way switches not working in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved 👍
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Recommended Sponsor News
Hi everyone,
