2 way switches not working | Page 4 | on ElectriciansForums
Discuss 2 way switches not working in the UK Electrical Forum area at ElectriciansForums.net
Loky11
North yorkshire
Now guys,
Need some help please, i have a 2 way switch that not working correctly, got a 2 gang 2 way switch on landing of 1st floor, on second floor there's a 1 gang 2 way switch, now the problem is that if the light is turned on from 1st floor it can not be turned off from 2nd floor and vice versa, it will only turn off from the switch that turned it on. Is it possible that the wires in the switches arnt wires in the correct terminals ? All advise appreciated. Cheers.
Here's my entry for the scrappiest sketch competition RB eat your heart out.
I think you have the situation marked (4).
[ElectriciansForums.net] 2 way switches not working
First, we can confirm the scheme:
And then if it is parallel fed as expected, which lead is which:
I did consider this but it's unlikely. As both switches have an effect, there must be switch operation between common and one of the other terminals. The third would have to be S/C to Com, which seems very unlikely. If it were welded in one position, that switch would likely have no effect at all. A S/C across L1 and L2 would keep the light on all the time.
OTOH the OP has swapped wires around in the past, so a miswire seems very much more likely. Hence also, my suggestion to test the wire functions without the switches.
I reckon at the underfloor JB the two three cores will be there as well as a supply and the switched live/neutral cable to the light.
Quite likely then that the live supply will feed one 'common' and the switched live to light will be to the other 'common'. Then both 'L1's and 'L2s' will connect together 1 to 1 and 2 to 2.[Aka strappers] If this were the case you could establish which cores should be L1 and L2 at each end by a simple continuity test which would tell you which colour should then be common at each switch, obviously test with the circuit isolated and lamp out at the problem light. And I wouldn't rule out different colours for common at either end, seen it before. :)
update. So i traced wire from 2nd floor switch back to a junction box, but as i was tracing wire back i came across this bugger (see photo) seemed the bas**rd plumbers decided to whack a screw straight through the cable and im guessing this in effect has made the switch live become permanent live. Any way all sorted now.
Cheers for you help boys :thumbsup:
When was the work carried out that caused this?
In the last 2/3 months, now thinking back it all adds, replaced the switch in top floor about 7 month ago and all worked then plumbers cam in, did their bit and was only on friday id gone to screw the switch fully back (left slighly off for deccys) and some one went to turn the light off at the switch on 1st floor and light stayed on, the only person to have to floor boards up at anytime was plumber.
Reply to 2 way switches not working in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
