Disconnecting circuit in CU - best practice? | on ElectriciansForums
Discuss Disconnecting circuit in CU - best practice? in the UK Electrical Forum area at ElectriciansForums.net
Deuce
Stamford
Hi all,
I'm in the process of renovating the bathroom. There is an electric shower I have removed and won't replace. The cable is not practical to remove.
To make this redundant circuit safe, what is the best way to cap off in the CU? I plan to label it too, both in the CU and at the other end in the loft. This end originally ran to the isolator in the bathroom, which is now removed. The final couple metres cable from the isolator to where the shower was, is deep in the wall so can this just be cut back and buried?
Someone else said to terminate the old cable to earth bus in the CU but I've never actually seen that done before, having looked at many CUs in older properties with redundant circuits..
If the end is left in the CU, the live conductors should be made safe, but the earth wire still connected. Other end should also be made safe, by termination in joint box.
If the cable is removed from the CU, not need for any termination IMO. However, you never know when this cable might come in handy, and perhaps left so it can easily be reused.
Thanks Midwest.
What would you normally cap the lives with? Just terminal blocks and label?
Inside CU seems easiest place to leave it, but don't want stuff floating around in there.
You can see some on a CU change I did the other week.
[ElectriciansForums.net] Disconnecting circuit in CU - best practice?
Reply to Disconnecting circuit in CU - best practice? in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
Recommended Sponsor News
Hi everyone,
