When Wet-Pants does the Muc-Spreading | on ElectriciansForums
Discuss When Wet-Pants does the Muc-Spreading in the UK Electrical Forum area at ElectriciansForums.net
-Matt
England
Got to a job of a second fitting this morning, and went from a rather good mood to ----ing ----ed off when i noticed all my sockets were completely full of plaster and most of the light switches where completely filled and plastered over. :mad:
[ElectriciansForums.net] When Wet-Pants does the Muc-Spreading
There was a data socket to the right, completely hidden!
I immediately went to drag the main builder so he could explain to me what the ---- he had done, to be told “the plumber was short on work, so did the plastering”
I stole 2 of his lads to dig my boxes back out for me, after re-locating where i had put all my sockets and switches etc.
Who managed to break the lugs on 2 sockets after smashing them with a chisel.
I had even gone to the effort of making sure all my cables were nicely coiled up inside the boxes, i should have left them all stucking out!
Just what do these people think they are doing???
The general dumbness and couldn't care less attitude that's everywhere now is so frustrating, just today I was fitting a built in oven to a new housing -left a note for the kitchen fitter to leave the backboard out as the housing would then be just over 500mm deep and the oven is 560mm, guess what he did ??:mad::rolleyes:
For a plumber, he's made a remarkably good job of plastering. not including filling the boxes.
Unless the wall isn't as flat as it looks on the pic
watch out or you'll be getting mentor status on the wet-pants forum.
You could have brushed a bit of mold release,in them boxes,which works a treat and is cheap enough. This,i prefer,as you end up with nice,crisp,square edges,for your faceplates.
Plasterers don't all like 4 sweeps,from every opening,and float and skim,needs something to sit on,if it is to stay flat,whilst hardening.
I realise a lot of the banter on here,is in regard of plasterers you have no control over...but doing a little extra prep,for one that knows his job,pays dividends.
I have just finished my youngest's bedroom,which me good friend,plastered. Double sockets,switches and media outlets,everywhere....and not a single one,where you could put a ruler across and slide in a 25 thou feeler guage :)
Had the same on a job,plaster & screed filling boxes.
Bloke in charge said it was my fault,should have put cardboard in the box on 1st fix to avoid it.
I lost it with him.
Filled a day work sheet,passed it on to the builders,still didn’t get paid though.
Just been doing a kitchen refit myself. Similar thing, not only boxes full of plaster, but cupboards fitted over the top without cutting out for the accessory, or even marking out where they were.
Oven/microwave cupboard similar with back in place.
Pelmets falling of when installing led strip.
Dot and dabbing a wall where originally it was to just be plastered, leaving my back boxes seemingly in the next room.
Plastering up to and around a temporary socket I left for the customer/builder.
Builders tools spread everywhere, along with boxes of kitchen cupboards, all in the work area
The kitchen in question would now be finished, had the builder not cleared off, leaving tiling to be done so I cant fit the new accessories.
The idea of a visit for first fix and another for second fix went out the window ages ago.
Did a nice job a while ago. House ground floor opened up and I first fixed with lighting cables through the plasterboard ceiling for about 10 surface light to be fixed.
Returned after plastering and there was a lovely smooth plastered ceiling, with no cables - they had pushed all the cables up into the ceiling void.
No access from above as the underfloor (wet) heating pipes were now in the floor.
I took great delight in chomping great holes in the new plaster to discover the cables.
Reply to When Wet-Pants does the Muc-Spreading in the UK Electrical Forum area at ElectriciansForums.net
I opened up the CU again and the round junction box above and what I found was the blue and brown wires coming in from the wall just above the 15a...
2 3
    • Winner
Recommended Sponsor News
Hi everyone,
