Need to install a load of outdoor sockets to be used for Air-Con equipment (vac pumps etc) local to some condensers.
Anyway I was just wondering if there is such a thing as an IP rated 3 position rotary switch?
The idea is that the normal rotary isolator could power the condenser in position 1, Isolate in position 0, and in position 2 just power an IP rated RCD socket.
I'm probably just dreaming but it would save a lot of time and hassle on a job I've got coming up. Less time I spend on this site the better!
