Metal all the way, no brainer | on ElectriciansForums
Discuss Metal all the way, no brainer in the UK Electrical Forum area at ElectriciansForums.net
london
Hi all, just thought i'dd share the picture of the live distribution board we came across this afternoon following a callout
not only was this live when we got there (seems that the fire brigade removed the wrong fuse from the ryefield board) but is a shocking example why every old distribution board should be changed to metal asap
[ElectriciansForums.net] Metal all the way, no brainer
If it was nothing to do with the fuseboard, you’d probably have to put a temporary supply in for the clean up anyway, wouldn’t trust a metal board after the fire service spraying their hoses all over the shot!
What a strange thread, this is a shocking example why every old distribution board should be changed to metal asap backed up by the distribution board was not even the cause of the fire!
I should hope you are not preaching this to your customers.
Reply to Metal all the way, no brainer in the UK Electrical Forum area at ElectriciansForums.net
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
There is no homework, and I'll never see these photo again.
Recommended Sponsor News
Hi everyone,
