Advice wanted - unhappy with rewire | Page 3 | on ElectriciansForums
Discuss Advice wanted - unhappy with rewire in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Hi all
Hoping I could get some independent advice on here. We've just bought our first property and had to get a full house rewire on the property (3 bed semi). Our electricians had finished the work within 2 days (2 electricians working on it). When asked when they were coming back, they said they didn't need to come back for a second fix as they'd finished it all. As we didn't know any better, we assumed all was fine and paid up because that said they wouldn't give paperwork till payment was made.
Since then, we have had a few issues. Our plasterer has been really surprised at the poor standard of work - they have had to plaster around all sockets and spotlights in kitchen.
1. The holes made to put in the sockets are generally quite a bit larger than the face of the external socket casing.
2. One of the sockets had a loose wire that was not connected when the plasterer was plastering around.
3. Another socket melted the builder's plug (smoke coming out as well), but didn't activate the trip switch.
4. An armoured cable they put in to light the garage is coming out of the consumer unit and through the floorboards in the bedroom in front of (rather than behind) the skirting board.
5. No paperwork 3 weeks after despite chasing him for this before everything else happened.
Would really appreciate any feedback as not sure if these are common or we really are within our rights to be taking this further? We tried contacting the electrician a couple of days ago, but he's not able to come till Monday evening, but his general response is telling me that he's blaming the plasterer's work.
Thanks!
Hold on there mate.A bit OTT.So for screwing accessories on too early they need reporting to numerous organisations for this heinous crime? Get a grip.It's posts like this that get my goat:mad:
It's unsafe work and taking advantage of unsuspecting members of the public that get my goat. I'm well aware of the standards on this forum. Your attitude doesn't surprise me
I take it the unsafe bit is the fact the line conductor has come out? For all you know the plaster could of been yanking it around left, right and center. Because it’s been 2nd fixed before its been plastered you think it’s acceptable to report the contractor to the their scheme and also the local council....Have a word o_O
The second fix has been done. That is the connection of all the accessories, testing, and energising.
This should not have been done ahead of the plastering but that is down to what arrangements were in place between you and all trades.
You should have received an EIC and building control paperwork.... keep pestering them for this, all in written form, and if they ignore you it's time to get in touch with trading standards and/or the scheme that your electrician belongs to.
Why do I get called dumb for stating what this fella and any reasonable person would state
What's the term we often use for competent person schemes on this board and in the industry generally? Is it scam?
It wasn't done right. It was unsafe. If it was tested when it was finished where are the certificates. If there's no certificate did he inform her, in writing to cover his back, not to switch it on?
Does safe locking off include for example a lock?
why shouldn’t it of been switched on, if all tested and screwed back?
From the pic, it wouldn't have taken much for the cable to come out, as it looks like it's only had connection at the tip of the wire.
[ElectriciansForums.net] Advice wanted - unhappy with rewire
Lets see what he has to say on Monday.
Many moons ago as an apprentice, I had my spell on “house Bashing” Four of us, 1 electrician, 2nd and 3rd year apprentices and a labourer. We could rewire a house in a day, mostly done by 2/3 o’clock, some times we were there till 8pm!
We would chop out, fix boxes, wire, cap then 2nd fix in the day, the plasterer would follow the next day....this was standard on Housing Association properties. Not ideal but it is done that way.
So 2 electricians over two days is about the same pace.
The chasing isn’t the best but it certainly isn’t bad.
The melted socket is likely to be caused by what has been plugged into it (plasters 110v transformer would be my guess)
The loose wire is a bit more worrying and is probably down to rushing. Proper testing should have detected that issue.
The SWA going in front of skirting.....who knows why, perhaps there was something obstructing the route behind the skirting or being in a rush it was quicker to put it in front
If a customer is unhappy with any trade’s work or service, the first course of action is to approach the company or individual to discuss and agree remedial work. I don’t understand why @Blaspark is suggesting reporting the electrician to their scheme, the council, etc. particularly when the sparky has already arranged to go back on site. If he/she could not be contacted or had been dismissive that would be a different case, but that’s not what Sarah has outlined here. Anyway, even if the scheme were notified, their first course of action would be to contact their member, whom would rightly say the job is not yet finished and there’s a visit already arranged with the customer for Monday. No further action is needed at this stage.
The line conductor that pulled free probably won't have shown up in tests. The screw seems to have indented the copper (albeit in the wrong place) so there would have been a solid metal-metal connection when the testing was done. It was mechanically weak because it wasn't inserted far enough into the terminal.
The problem with this issue is that while it is probably a one-off, it could also point to a bad termination technique on the part of one of the installers, who might simply not be in the habit of tug-testing etc and might have done the same in other fittings.
The burnt socket could be anything, possibly the plug that was inserted. If the front of the socket is more burnt than the terminals at the back, it wasn't the electricians' fault. If the terminals are badly burnt, I would suspect another inadequately inserted cable and would then be keen to have all accessories checked. OP- you wouldn't necessarily expect anything to trip due to bad contact that causes overheating. The MCB would trip in the event of a short-circuit, and the RCD in the event of a leakage e.g. shock to a person. Means to detect this kind of fault (AFDDs) are just being tentatively introduced. They have to be pretty sophisticated to tell the difference between a heater heating up and a plug heating up!
2 days, 2 blokes. rushed job, i'd have allowed a week for 2 skilled sparks to do the job right. ( used to be 4 days, but at 72 i is slowing down a bit, knees and back refusing to obey brain ).
I wouldn't agree there. To be honest inspection would be far, far more likely to pick that up than testing. If there was fortuitous contact between the conductors during testing there is no likelihood of finding that through test readings. It's possible to pick up poor contact resistance but it really depends how the two conductors are seated. If the contact is good between them (though not securely screwed together) I don't think passing 200mA through them will tell you much.
basically old scholl like what i was taught. wriggle and pull.if it don't come out, it's good. sod these digital devil's overpriced MFTs. eyes have been finding faults long before the LCD screen with half the characters missing were invented.
Reply to Advice wanted - unhappy with rewire in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
When he bought the bank, they stripped out all the metalwork, iron bars etc for scrap. He was left with the cashier countertops… which have been...
Hi again, "trying to save money" doesn't really come into it. We parted company with the original sparky, as he was so unreliable. Jon
What is the distance from the point outside the house to the shed?
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
