just received this item. multimeter with waveform graph. unbelievably only £47 inc. shippling. what will them chinese get up to next?
Discuss for all you tool tarts out there. in the Electrical Tools and Products area at ElectriciansForums.net
ok, so this is the output waveform from a 400watt dimmer supplying a 60 watt load at approx, 75% full. and @darkwood. it's not a sticker. .Are you going to do a 'review' on it?
Bung it on a dimmer switch and see how accurate the graph is.
That is just too good !!!ok, so this is the output waveform from a 400watt dimmer supplying a 60 watt load at approx, 75% full. and @darkwood. it's not a sticker. .
Vrms = 0.3535 * VppThe 173v rms?
From the increments can you work out peak to peak.
Does it show any spikes at switch on?
Reply to for all you tool tarts out there. in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
