Removing socket outlets | Page 3 | on ElectriciansForums
Discuss Removing socket outlets in the UK Electrical Forum area at ElectriciansForums.net
Rugby
Hi guys and girls,
A client is moving their kitchen into another room that currently has a few sockets in it.
The sockets are currently on a ring final circuit that covers every socket in the house.
They've asked me to add sockets for the new kitchen so I am going to run a new kitchen circuit most of which can be done in trunking as it will be behind the units going in.
My question is am I able to replace the faceplates of the old sockets not being used/covered with a blanking plate and use maintenance free wago's inside so the ring for the rest of the house is not affected? (3 sockets I think that will end up behind units)
Thanks in advance
Not seen the small units before, but do they offer cable restraints? This is one of the main factors in a MF connection.
They have the rubber fins on cable entry to hold the cable sheath firm like the larger box, but not the moulded plastic "stalls" that the connectors live inside.
The smaller boxes are a through box with cable entry each of the short ends rather than the one end.
For lighting circuits I believe, never used em though....
[ElectriciansForums.net] Removing socket outlets
time you bought the wago box, wagos, earth sleeved the cpc's, closed box with pipe grips, better off paying £4 for the quickwire solution.
I don't think either of those are stamped with MF. The smallest MF ones I've seen are around 4x4" and appeared identical to non MF ones in terms of cable restraints apart from size and being stamped with the MF symbol.
The larger one is stamped MF inside the lid. Hard to see on my pic though, even zoomed in.
Love the quickwire push in system, but I find wagos in boxes better to keep as they are completely flexible in the connection configuration. Quickwire only do one specific job.
Reply to Removing socket outlets in the UK Electrical Forum area at ElectriciansForums.net
seems to be a big song and dance over this one guys, this is bottom basement stuff and seriously I cannot believe one the thread was put up and...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
Recommended Sponsor News
Hi everyone,
