Removing socket outlets | Page 2 | on ElectriciansForums
Discuss Removing socket outlets in the UK Electrical Forum area at ElectriciansForums.net
Rugby
Hi guys and girls,
A client is moving their kitchen into another room that currently has a few sockets in it.
The sockets are currently on a ring final circuit that covers every socket in the house.
They've asked me to add sockets for the new kitchen so I am going to run a new kitchen circuit most of which can be done in trunking as it will be behind the units going in.
My question is am I able to replace the faceplates of the old sockets not being used/covered with a blanking plate and use maintenance free wago's inside so the ring for the rest of the house is not affected? (3 sockets I think that will end up behind units)
Thanks in advance
I would access the cables above these sockets in the ceiling. I would access from below as there's a pretty good chance some plastering must be going on so the small holes you make in the ceiling can be filled. I would then join the cables in a MF wago and leave in the ceiling.
I doubt the old sockets will be in an ideal place behind the new cupboards, also I doubt that the owner will want big holes cut in them simple so he can see a blanking plate in order to create the needed electrical zone. The kitchen fitter will end up just covering them up with the cabinets and then there will be live cables hidden in the walls.
If the new layout allows, I would leave the sockets in place and cut access holes in the rear of the cupboards..... or if the cables come from below, get them out of the wall and use Hager MF boxes ........
I'd love to try and explain that to a customer - yes Mam I know your kitchen cost over £20k, but it was easier for us to put the big holes in the back of the units rather than remove the sockets properly.
So can i just confirm, if I use a crimp and shrink or inline splice and then put a blanking plate then it will be classed as MF? I don't want to cut holes etc in cupboards the ring main could do with having a few less sockets on it as it is haha.
Hi guys and girls,
Thanks in advance
If you can get access to the leg in and leg out under the floor, I think it' be a better job to cut out the old sockets and link the old legs under the floor in MF boxes.
A row of blanking plates on the wall is going to look ugly and it's only a matter of time until someone removes them and skims over.
Then you'll have live cables in the wall with no obvious route indicators.
Try to go d the legs and do it properly, all in my humble opinion of course.
Split ring remove Surplus sockets join back up with wago’s and wago box under cabinets behind plinths ! Just remember to try and leave enough slack to make it easy in the future to check em.
Reply to Removing socket outlets in the UK Electrical Forum area at ElectriciansForums.net
And metal backboxes partly full of pink plaster smacks of lazy DIYers, or equally lazy professional sparkies.
seems to be a big song and dance over this one guys, this is bottom basement stuff and seriously I cannot believe one the thread was put up and...
