Got sent this, RCD Failed x1 greater than 300ms maybe if they changed the supply at top of RCD, currently have neutral on the left and line in the right , also the RCD is fed from 63Amp MCB is that all good just feeding an RCBO 30ma board
Discuss RCD trip time greater than 300ms in the UK Electrical Forum area at ElectriciansForums.net
Yes, should still trip within 300ms X1 possibly cause the L wants to be on the other side?that's a time delay RCD. and MK RCDs are generally L on right.
Reply to RCD trip time greater than 300ms in the UK Electrical Forum area at ElectriciansForums.net
