12V DC Relay Issues (Diesel Engine) | on ElectriciansForums
Discuss 12V DC Relay Issues (Diesel Engine) in the UK Electrical Forum area at ElectriciansForums.net
Vancouver, Canada
Hello all. I am having an issue with a 12V DC Relay I am trying to install to run a kill switch on a John Deere Diesel engine that runs a high pressure water pump. I have the relay wired in such that it will send power to the ignition when an electrical signal comes from a water sensor in the pump (dry running protection). The issue I have is that whenever it is hooked up all I get is chatter from the relay. I have tested my wiring by connecting the "switch" wire to battery and everything works as it should. I read somewhere that if the switch voltage is less than the feed that it can cause chatter. The fees voltage is 12.56 and the switch voltage is 12.22. Could this be the reason and how should I go about fixing it? Thanks
  • [ElectriciansForums.net] 12V DC Relay Issues (Diesel Engine)
So the signal from the water sensor is ok then and this is not causing the relay to chatter?
I presume you don't have a variable power supply. To feed 12.22v from this to the relay and still see if you get chatter...
A 12V relay will usually pull in around 8-9V on the coil, and will hold in down to about 6V. Anywhere between 9 and 18V should be OK, it is not critical. There is no relationship between the coil voltage and the contact switching voltage. Probably, the sensor output is not giving a steady voltage, or there is a bad connection somewhere, or the relay is not actually a 12V relay.
Okay thanks. I will check with the sensor manufacturers and see if it is constant or not to double check. If it isn't, is there anything that can be done or a different style relay to use?
What type of output does it have - contact closure, open collector? Is it designed to operate a relay or just trigger an electronic input of a system controller?
Reply to 12V DC Relay Issues (Diesel Engine) in the UK Electrical Forum area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
