Hello all. I am having an issue with a 12V DC Relay I am trying to install to run a kill switch on a John Deere Diesel engine that runs a high pressure water pump. I have the relay wired in such that it will send power to the ignition when an electrical signal comes from a water sensor in the pump (dry running protection). The issue I have is that whenever it is hooked up all I get is chatter from the relay. I have tested my wiring by connecting the "switch" wire to battery and everything works as it should. I read somewhere that if the switch voltage is less than the feed that it can cause chatter. The fees voltage is 12.56 and the switch voltage is 12.22. Could this be the reason and how should I go about fixing it? Thanks
