Measuring current using a Shunt Resistor & an Oscilloscope | on ElectriciansForums
Discuss Measuring current using a Shunt Resistor & an Oscilloscope in the UK Electrical Forum area at ElectriciansForums.net
Mexico
Hi people, I'm new using forums for this kind of purposes, so please forgive me if I can't explain myself well, also if this is the wrong sub-forum please tell me ¡.
I have to measure the output current & voltage of a High Frecuency, High Voltage transformer, I can measure the Output Voltage using a High Voltage Probe and my Handheld Oscilloscope, but I still have to deal with the current, I want to use a Homemade Shunt Resistor (0.1ohms) and my Oscilloscope, but before doing it I tried by measuring that voltage with my Fluke Multimeter, I was increasing the input voltage & It was working well but at some point my Multimeter Screen started to fade & show random numbers, What happened? The voltage on the Shunt wasn't that high (around 2.5 volts) when it started to fail, it still works. I don't want to damage my Oscilloscope, so I need to now what causes that issue.
Here is my circuit diagram if you wan't to know the way I'm measuring.
Considerations:
-I know my multimeter doesn't measure at those frequencies, but the error is constant so I can just adjust it.
-I know my oscilloscope does work at those frequencies.
-I have no idea of the value of the output current & voltage, also by measuring another transformer the values are not consistent.
  • [ElectriciansForums.net] Measuring current using a Shunt Resistor & an Oscilloscope
One needs to know more about V1 eg: waveform?, output impedance as a function of frequency - what is its Thevenin 'equivalent circuit'?
Similarly, one needs to know more about the transformer - what is its 'equivalent circuit'?
The Fluke multimeter I think is likely to be an unsuitable instrument for your measurements.
The secondary current you measure depends on the source of emf 'looking left into the secondary and its waveform', the impedance looking left into the secondary and the impedance of the load - plus the impedances and frequency & waveform characteristics of your instruments.
Need some more detail from you.
Your measurement setup with the oscilloscope looks OK but safety first, the resistors suggest you have a high-voltage, high-current supply and if you're not secure with measurement principles I wonder if you have the expertise to be safe around the supply.
What is the output current and voltage and how are you protected from it?
Hmm, meter display going blank sounds a bit spooky and not obviously related to the measurement. Probably just coincidence.
Hi - I’m back with the frequency being out of the meter’s range. Not sure what the point of measuring something that you know will be wrong?
Hi, sorry it took me ages to reply but I'm kinda busy at work.
You're right, but I wanted to know if the error was somehow constant, & it was (kinda), I don't have access to any other meter so I'm stuck with it.
Here's the relation between the real output & what the meter shows.
Hi, I know that should provide that kind of data, but sadly I can't show them, what I can show is this:
The input's waveform looks like a square (I'm attaching a pic & yes, where I'm working I only have access to Paint :l).
I still need to do the Thevenin Analysis, It's not that hard but they want me to focus on something else.
My instruments.... I'm stuck with them, I already measured the error, the results are shown in a reply above.
My output waveform looks like a M, I'm also attaching a pic showing it.
Thank you very much, you seem to know a lot.
Hi, & thank you for replying <3.
I haven't had a proper training on that (if there's any), I have no idea about the output voltage & current (actually that's the reason I'm trying to measure it), but the voltage is around the 3.8KV.
About security.... there's none, we don't have security equipment.
Thank you very much.
Re #8. The two waveforms tell you a lot. The equal mark:space ratio of the square wave means it contains only the fundamental sinusoid (20kHz) and odd harmonics of it ie: 60kHz, 100kHz, 140kHz,....
The waveform of the output voltage/current shows it is mainly comprised of the fundamental (20kHz) and third harmonic (60kHz).
Is your measurement question:
a. 'what is the effective root mean square(rms) value of this second waveform?' or
b. 'what is the amplitude of each component (fundamental, third, fifth, etcetera)? of this second waveform?'
Reply to Measuring current using a Shunt Resistor & an Oscilloscope in the UK Electrical Forum area at ElectriciansForums.net
Good point James. It would have been nice if the manual had mentioned which of the leads were being used for what though. It simply shows the LNE...
I don't think it will work with only one stake unless some meters have different operating parameters. It doesn't necessarily have to be a stake...
