Clamp meter that will measure milli amps | on ElectriciansForums
Discuss Clamp meter that will measure milli amps in the UK Electrical Forum area at ElectriciansForums.net
Keighley
Afternoon all. I’m looking to invest in a clamp meter but want want that will measure milli amps (nuisance tripping etc). The megger 305 seems the best about; is there any others out there? TIA.
If you don't want to spend that much then i can recommend this one.
So is that one any good then?
You get what you pay for.
(Drop unknowns on the floor = drift)
( compare with a "Known" situation at home for some stability )
But you could pay for quality - and have it banging about in the van -little used for years !
(With all this DC type RCD/RCBO changes ,I'm still unsure what is around the corner)
[ElectriciansForums.net] Clamp meter that will measure milli amps
I use one of these. Being able to move the clip separately is handy. Just make sure it pointed in the right direction. I often couple it up with the other one for signal faults, Fluke-709 | Fluke 709 Multi Function Calibrator | RS Components - https://uk.rs-online.com/web/p/multi-function-calibrators/7769529/ . Very handy if you carry out fault finding[ElectriciansForums.net] Clamp meter that will measure milli amps[ElectriciansForums.net] Clamp meter that will measure milli amps on your own.
View attachment 51091View attachment 51092
I use one of these. Being able to move the clip separately is handy. Just make sure it pointed in the right direction. I often couple it up with the other one for signal faults, Fluke-709 | Fluke 709 Multi Function Calibrator | RS Components - https://uk.rs-online.com/web/p/multi-function-calibrators/7769529/ . Very handy if you carry out fault findingView attachment 51091View attachment 51092 on your own.
just seen the price.could buy a van and a MFT for less.
Reply to Clamp meter that will measure milli amps in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
