Guest viewing is limited
Afternoon all. I’m looking to invest in a clamp meter but want want that will measure milli amps (nuisance tripping etc). The megger 305 seems the best about; is there any others out there? TIA.
look for the resolution. think it's 0.1mA which is fine for tracing earth leakage.
So is that one any good then?
You get what you pay for.
(Drop unknowns on the floor = drift)
( compare with a "Known" situation at home for some stability )
But you could pay for quality - and have it banging about in the van -little used for years !
(With all this DC type RCD/RCBO changes ,I'm still unsure what is around the corner)
I use one of these. Being able to move the clip separately is handy. Just make sure it pointed in the right direction. I often couple it up with the other one for signal faults, Fluke-709 | Fluke 709 Multi Function Calibrator | RS Components - https://uk.rs-online.com/web/p/multi-function-calibrators/7769529/ . Very handy if you carry out fault findingfluke771.jpgFluke709.jpg on your own.
@Haworth
Just in case you didn't realise, David is having a bit of fun with that recommendation. Don't clamp a 771 around an AC line, it... won't appreciate it.
As for AC leakage clamps, I use an AEMC model 565. It has a high range to 100A AC, low range to tens of microamps.
View attachment 51091View attachment 51092
I use one of these. Being able to move the clip separately is handy. Just make sure it pointed in the right direction. I often couple it up with the other one for signal faults, Fluke-709 | Fluke 709 Multi Function Calibrator | RS Components - https://uk.rs-online.com/web/p/multi-function-calibrators/7769529/ . Very handy if you carry out fault findingView attachment 51091View attachment 51092 on your own.
just seen the price.could buy a van and a MFT for less.
Keighley
Clamp meter that will measure milli amps
Haworth,
rapparee,
