Discuss Industrial Plug. Can't identify in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for help James, do you have an idea if it is still on production? Or maybe there is a alternative to it?I think it might be off an old lighting distribution trunking system.
put in slot, turn through 90 degrees to connect and hold in.
@ruslan that plug should have the voltage and amperage on it and this is a male plug, once you have that information you can find the female plug. That looked like it plugged into a buss ducton the end of the buss bar trunking, there is a box with a word on it, that is probably the manufacturers name.
(steel box)
Reply to Industrial Plug. Can't identify in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
