If you were wiring 8 gangs of 2 way light switches. Would you wire 8 independent circuits, so 8 no. 3 core between switches. Or would you run a live, and loop all the L1's together, then just run 8 no. 2 core between switches ?
Discuss 8 gangs of 2 way light switches - wiring in the UK Electrical Forum area at ElectriciansForums.net
Not when it's all labelledEight gang switch in a dwelling that won't cause confusion.
Only his legs., put your wiring diagram on here and we will look at it.No harms done
That'll look nice. My mum has a two gang switch in the hall one switch for the hall the other for the landing and for the last fifty years she clicks on and off until she gets the right one. I reconnected it and said near switch hall, far switch landing but it made no difference.Not when it's all labelled
I bet saved her legs, I be theirs a trench in the carpet.That'll look nice. My mum has a two gang switch in the hall one switch for the hall the other for the landing and for the last fifty years she clicks on and off until she gets the right one. I reconnected it and said near switch hall, far switch landing but it made no difference.
As with a lot of publications of this type while they are not statute documents they can and quite often will be used to support a case litigationYup, I know CY/YY/SY is not 'approved' under certain UK regs because, as I understand it, it was too much hassle and expense for the manufacturers to bother. So one writes it down as a departure, used for good engineering reasons and to equal safety standards. British Standards publications are not law, only a guide to one (good) way of doing things.
As previously posted they are control cables that are generally used in industry for machinery control circuits which are under numerous other British StandardsOtherwise, why are these excellent cables even sold in the UK? ...
How far would you argue your case with a man or woman wearing a funny wig or the expert witness that they may get to give evidence against youI'll argue with anyone that my occasional use of SY is better than say cr@p flimsy T&E clipped to a wall in a public building. The latter is entirely compliant, but that doesn't stop it being cr@p.
I rather like having that earthed braid over everything, cf. Flexishield of which I also use a lot.
I’m intrigued, how have you seen it installed incorrectly?Personally for me the crap cable is FP and it's derivatives you see it more often than not incorrectly installed so much that IMO it should be banned from use as a safety cable
If you read the manufacturers installation instructions for FP it should only be clipped with metal clips or ties but so often it is fixed with plastic knock on clips, plastic cable ties and other similar fixings that melt in a fire and allow the FP cable to fall and then it will not maintain it's fire integrity under the BS to which it is testedI’m intrigued, how have you seen it installed incorrectly?
get an electrician in for this work. You could always do the chasing and floorboard lifting. No offence intended, but at least you know it will be done correctly and also certified.
Seeing the state of some installs on YouTube there are a lot of incompetent sparks out there wiring up housesSorry to disagree, but getting an electrician in doesn't ensure it's done properly
I would love to see a pic of the 8 gang after it's been labelled up because I'm tying to picture it in my mind as to how aesthetically pleasing it's going to look in a domestic environment.Not when it's all labelled
Do you mean electrician or a bright spark ?I am a spark....................
Reply to 8 gangs of 2 way light switches - wiring in the UK Electrical Forum area at ElectriciansForums.net
