8 gangs of 2 way light switches - wiring | Page 6 | on ElectriciansForums
Discuss 8 gangs of 2 way light switches - wiring in the UK Electrical Forum area at ElectriciansForums.net
Kent
If you were wiring 8 gangs of 2 way light switches. Would you wire 8 independent circuits, so 8 no. 3 core between switches. Or would you run a live, and loop all the L1's together, then just run 8 no. 2 core between switches ?
Reply to 8 gangs of 2 way light switches - wiring in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
