Hello,
We moved into our house 2 years ago and until recently the kitchen lights worked fine. The LED strip lights are on a dimmer switch, when pressed (full power selected) the LEDs come on briefly and then go off. On investigation the LED strips are driven by an Aurora driver (this model Aurora 12V Constant Voltage LED Driver - 16W - AU-LED16T - https://www.ledbulbs.co.uk/products/aurora-1-16w-12v-dc-non-dimmable-constant-voltage-led-driver-blue) Image attached. Further reading indicates that this driver can't be used with a dimmer switch so is this likely to be the cause of the issue?
If so can anyone suggest a good replacement dimmable model please?
Regards
Stephen
Regards
Stephen
