Dodgy trade pictures for your amusement! - 1 Million Views! | Page 410 | on ElectriciansForums
Guest viewing is limited
Darkwood
Yeah I use the 221 5 ways, you have to use the lever instead of forcing it in with stranded. I cut it back and it was twisted neatly when I stripped it. The conductors weren't long enough unfortunately so needed extending. Technically it was two spurs from one point I suppose and I could of used lots of two way ones.
You should always use the lever with a Wago that has that facility, the days of forcing in a cable are a while ago and the old type of Wago, in fact I don't think they make them anymore, certainly I can't find them on their web site, but TLC still have them, in preference I would always use the lever type.
You still get the push fit style Wagos, they have a couple ranges of them at least - the 2273 are newer and smaller, and there still is the 773 series
So they over clad the original ceiling by the looks , I often find those big transfomers feeding a bunch of 12v spot lights wired like that using twin flex and connector block
The issue is often getting to the transformer which is often inaccessible without mashing a hole somehwere
It’s a good job I’m only 6ft and 15st. Otherwise it would have been a really really tight squeeze to sort it. Instead of just the really tight squeeze it was! 🙄
But I did just about did it, without cutting the ceiling. 😇 Now I just need to clip the cables with some fire clips as best I can and wire in the new downlights.
Funny , I used to work with a sparks who was about 6'2" and about very heavy set but he managed to crawl into spaces you wouldn't believe possible...
I sometimes had to pull him back out by his ankles 😁
Recommended Sponsor News
Hi everyone,
