Matter
Discuss Level 2 electrical installation course in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Ah thanks so you wouldn't have to go to do another course at college to get the NVQ level 3. You could just this all in the work place. Is conjunction with the level 3 diapolma?You could attain the NVQ around the same time as completing Level 3, provided you have gathered sufficient evidence for your portfolio.
Thanks so how did you get your qualifications?Depends what you want to do. Most employers don't recognise these qualifications so after 2 years of study you would be expected to work for mates/apprentices wages while you build up real life experience.
I did level 2 at college and it was a waste of time in terms of gaining knowledge and experience. The other kids were passing and didn't know what an MCB was.
I didn't get that one, i dropped out and went to work as an improver instead, then i funded my qualifications myself through earning more money at work. Still got my NVQ3 to go.Thanks so how did you get your qualifications?
What's am2 please? Can you do the nvq if not working as an electrican? I am a plumber/gas engineer. Thanka
Correct apprentice nvq level 2 and 3 one day a week while working as a plumber/gas engineer the other days.
Utter nonsense!Becoming a qualified electrician is achieved by pretty much the same route, apprenticeship going through the level 2 and 3 with mostly site work under a mentor and some college time.
Get out there as a 'mate' and start earning half decent money.So would be hard to achieve this on an evening doing the level 2 and 3 diapolmas
Thanks my position is in a plumber/gas engineer wanting to diversify.Get out there as a 'mate' and start earning half decent money.
Level 2 and 3 at college is gonna cost you 2 years of your life (at least - when the pandemic hit some colleges were put back by 1 or 2 years and some even more - i know lads who started in 2017 and still haven't finished due to that and other problems with staffing, supplies, equipment etc.) and several thousand pounds. Then when you have level 2 and 3 you're not considered qualified by anyone and will be on mate's money anyway.
Then there's the fact that college doesn't actually teach you anything about being a real life spark and only teaches you book-electrics.
Personally i wouldn't go that route and would try to get into the industry another way.
If i were in your shoes i'd go get the BS7671 regs book, copy of the on-site guide and the 'guidance note 3' and go pass your 18th edition. Then get an ECS/CSCS card and the world will open up to you.
Can you get an electrical cscs card with the 18th edition. Or do you mean a general cscs cardGet out there as a 'mate' and start earning half decent money.
Utter nonsense!
You can go and get your quals yourself whilst working, no apprenticeship, level 2/3 or college needed.
Absolutely, provably, 100% false. Unless you're trying to make 'apprenticeship' an umbrella term that means 'learning from anyone else in any capacity'. In which case everyone does an apprenticeship in absolutely every discipline.Not nonsense at all, an apprenticeship, formal or informal, is necessary.
Reply to Level 2 electrical installation course in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
