Dodgy trade pictures for your amusement! - 1 Million Views! | Page 425 | on ElectriciansForums
Darkwood
That is some awful pipework there! How many self cutting fittings can you fit on 1 piece of pipe?! They are not good fittings, anyone thinking of using them - don't!
Yep, that plumbing in pretty shocking to be fair. But when they’ve used 2.5mm red single to bond the draining board to the pipework, it shouldn’t really surprise you…😂
No main bonding on either Gas or Water services and both tested out to be extraneous.
Landlord’s going be happy when I tell him the work involved. It’s a nicely decorated property, and carpets / flooring all look pretty new….
How long is that SWA? Why did they install RCD protection but no OCPD? 🧐
But the RCCB is clearly marked 80A.
It's a bit over 20m, layed on insulation in a loft. I think it's 16mm.
Yup I'm sure they assumed the 80A was ocpd and not understanding it's a RCD only.
There's so many why's on that sub main. Why not buy the lewden board designed for the job or use a tails gland or why use green tape. Or most importantly why didn't they call an electrician 😀
I like how they used full blanks, which left no room behind for the way they routed the cables.
