Dodgy trade pictures for your amusement! - 1 Million Views! | Page 302 | on ElectriciansForums
Darkwood
West Yorkshire
I can't blame a fellow spark for this but some of the previous work was dubious to say the least.
I got a call to a pub that had previous evidence of a rat invasion and they had chewed through the cable supplying the outside lights under the floor space in the first floor.
Yesterday whenever the hand dryer was switch on it tripped the RCD. IR test showed a short on all three wires. Followed it back from the gents roof space above to discover this. Ehmmm nice wires says Mr Rat! My understanding is that vermin will chew through anything that blocks their path, rather than the thought that they are simply sharpening their teeth. The hand dryer was spurred off the lighting circuit for the toilets, neither the cable or the breaker were spec'd high enough to handle the power of the dryer anyway.
At first it wasn't really obvious that the chewing had happened until you pulled the wires back through the hole in the wall. What gave it away was the black marks all over the cable that something had been passing back and forth. The hole leads back under the living room floor for the accommodation above the pub. So I by passed the dodgy part of the cable back to the CU with a temporary cable, until the laminated floor can be lifted next week to see what lies beneath? My Jack Russell is coming with me next week just in case!!
Even better still, who saw the need for the wedge to hold the door open :nonod:
Not electrical but not sure how somebody managed this with a giant placard above it…
FFS !
It took me a while to work out just what I was looking at. But once I'd worked that out, that's shocking workmanship on an aircraft. And the reason for the specific notice ? I'd guess they've had incidents in the past when a control cable has become slack and got caught round the clamp bolt - not something that's going to make life boring for those on board.
But then, I've read/heard of worse maintenance issues in aviation.
Was asked to fit this new consumer unit in a static mobile home, bought from Fleabay.
I refused.
Tests carried out on these units on behalf of Leicestershire Trading Standards revealed safety concerns. The Residual Current Device melted rather than cutting power, some of the Miniature Circuit Breakers failed to trip, and parts of the circuit remained live even with the main power switch turned off.
FFS !
Yeah if the bolt for the band clamp is sticking up then when the aircraft is flying and you get slack in the cable then it can chafe on the bolt.
But yeah I’ve seen much worse people using the wrong grease on the landing gear so risk of fire as temp rating isn’t enough for the brakes. Another one somebody had crimped the socket end of crimp then shoved the end that is meant to be crimped into the connector
And this one from not to long ago where the main cable from the engine generator had been run on finger tight on phase A so it got so hot it melted out the lug
