Transformer burnt- reasons? | on ElectriciansForums
Discuss Transformer burnt- reasons? in the UK Electrical Forum area at ElectriciansForums.net
BC
Hi I recently purchased(aug18) a house built in 1963 and about an hour before bed I smelt a burning smell in the hallway. I looked around and couldnt figure out the source. Fast forward an hour and I can still smell the same smell but stronger and thats when I figure Id check the attic as the pull down stairs was in the hallway. I got to the top of the steps and noticed the attic was full of smoke with the source coming out from a piece of plywood that was loosly sitting there, I moved the wood over and saw a transformer box in the insulation smoking and once it had free air after I cleared the insulation the smoke started getting worse quickly. My wife shut off the main breaker after I started yelling CUT THE POWER CUT THE POWER!!
Lol jesus it was abit scary for sure. Just thought Id try and get an opinion as to why after 11 days of being there it would start to overheat, Some of the wires outside the box looked pretty charred for some time so maybe its been overheating for awhile? The switch panel has a few buttons that dont work but still made the transformer hum when pressed so maybe I had too many in the ON position and it overloaded it? Suffice to say tye walls are getting opened up and Ill be rewiring the whole thing. Cant live here worringing about electrical issues.
  • [ElectriciansForums.net] Transformer burnt- reasons?
Looks like the sort of pink cable nearest the camera has been overloaded (outer insulation melted) and I imagine the transformer has been overloaded too.
It's possible that a circuit in your house was put in by the previous owner with this constant voltage?/isolation?/step up?/step down? transformer, and you have plugged something in, obviously without knowing this lash-up was there, that has overloaded the wiring.
If you could tell us what's written on the transformer, or provide a photo, that might give a clue as to what it was there for.
To start with the wiring is awful and not by code. Transformers have to have ventilation and not covered by anything so I’m going to assume that the heat built up is what caused the most damage.
Reply to Transformer burnt- reasons? in the UK Electrical Forum area at ElectriciansForums.net
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
As you say it's plausible with a poor CNE on a TN C S arrangement but there would need to be very few parallel earth paths within the property and...
6K
B
Have you checked the alternator, engine and battery earthing points sounds to me like one or all of them needs attention
B
Hi wondering if you have any thoughts on an alternator problem I have?I replaced my alt last month and its been OK until today. When I took the...
Bryan Williams
B
S
went to job of mine in old pump house ,water dripping on suppliers meter and cutout caught fire leavin nothing.was lucky nothing flamable,elecy...
2 3 4
9K
p d stott ltd
P
