- Joined
- Jun 2, 2011
- Messages
- 76
- Reaction score
- 14
Discuss what would you say,Ze 14ohms in the UK Electrical Forum area at ElectriciansForums.net
How have you obtained a Ze as there doesn't even appear to a main earth present
- - - Updated - - -
it is tt then, there may not be an electrode , at this age the wire may go to a water pipe for example which would explain the low reading , 14 ohms is very low for an electrode unles its in waterlogged ground
What would you say to a reading of 0.29 ohms on a TT then? If you'd said it's not a bad reading I'd have agreed.it is tt then, there may not be an electrode , at this age the wire may go to a water pipe for example which would explain the low reading , 14 ohms is very low for an electrode unles its in waterlogged ground
I did **** on the rod though :smartass2:
Reply to what would you say,Ze 14ohms in the UK Electrical Forum area at ElectriciansForums.net
