Anyone recognise this MCB/switch? | on ElectriciansForums
Discuss Anyone recognise this MCB/switch? in the UK Electrical Forum area at ElectriciansForums.net
Does anyone recognise the switch at the far right-hand end of this consumer unit; the one marked 'LIGHTS' ?
Is it an MCB or a switch? [ElectriciansForums.net] Anyone recognise this MCB/switch?
The CU is is a property I'm buying. I think the cover is home made. It certainly has no IP rating with that big hole in it. I think it's as old Wylex fuse box behind the cover.
The main switch lever is broken as is the switch on the mystery MCB, which does look like a Dorman Smith - thanks to the forum members who suggested this.
The property is to be let out so at the very least the main switch, MCB and cover need fixing. Best option would appear to be a new CU, but I'm wondering what will fit into the flush housing in the picture. I'll probably post another question regarding this.
Thanks again for the pointers to Dorman Smith as the manufacturer of the MCB.
Buy a new CU, the Wylex type that is installed is older than the hills and the Wylex MCB I seem to recall being banned now so you would never be able to buy them (If this is a wrong train of thought on my part I am up for correction). The fact that CU has been butchered is a good reason to replace it.
If the space is too small then I would suggest buying two small CU's that can be stacked on top of each other, lighting in one, power in the other..seen this done a few times over the years.
Agree with the change Out'.....not heard of any ban concerning the mcb, though. Buying difficult, but do have a few...used.
I think the ban is an "effective one" in that the British Standard they were made too was revoked and there are no figures for them in 7671:2008 (Not sure about 7671:2001 though) which effectively bans them as you cannot work out disconnection times etc...I know Wylex haven't made them in at least a decade, possibly longer.
Reply to Anyone recognise this MCB/switch? in the UK Electrical Forum area at ElectriciansForums.net
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
Better off with the click prw213 as it has twin screw termination.
