Heating Engineer set me a challenge | on ElectriciansForums
Discuss Heating Engineer set me a challenge in the Central Heating Systems area at ElectriciansForums.net
Piece of cake .... Hacksaw through that 22mm pipe just as it enters the elbow making a vertical cut, then drag the elbow with the pipe attached to the right and forwards away from the plug.
Remove plug from socket and leave the plumber to clear the wreckage ....... :)
And don't forget to kill the power before unplugging, what with all that water everywhere! :)
Why get all technical, just smash the pipes to hell with your favourite lump hammer.
Is that a pubic hair stuck to the plug or is it cracked. If it's a pube you could probably identify the plumber with a quick DNA test ;)
Also that soldering is atrocious :)
I don't mind telling you, i had a hell of a job chasing out that back box and making good,with those bloody pipes in the way....:43:
Reply to Heating Engineer set me a challenge in the Central Heating Systems area at ElectriciansForums.net
Hi everyone, If you are looking for reliable EV chargers, check out our top-rated selection at E2GO! ⚡ Please note that all EV Chargers and...
    • Friendly
R
Heat Group Magnaclean copy. Parts of it are excellent. I was tidying up the boiler pipework on a bungalow I bought and plan to move into. Being a...
Ric2013
R
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
