Todays EICR gem - must be having one of those weeks | on ElectriciansForums
Guest viewing is limited
Discuss Todays EICR gem - must be having one of those weeks in the UK Electrical Forum area at ElectriciansForums.net
Welchyboy1
Nearly Esteemed
Essex
Three phase board in mechanics shop
no main earth conductor
ZE - 586ohms
no rcd
  • [ElectriciansForums.net] Todays EICR  gem - must be having one of those weeks
Havent touched it, only plugged my meggar into a socket to check zs
He wanted a price for a full eicr for his insurance.......lol!........, i said as soon as i see it, its basically a full re-wire and its dangerous, it needs urgent attention, he said he will call me.............
are they using any outdoor portable equipment?
Is there any socket outlets that could be expected to be used for outdoor equipment?
Check the condition of that enclosure including the security of fixing.
Check the bases of the OPDs...make sure they are OK.
What was the earthing arrangements previously?....any evidence of this?
where is the main intake?.....whats the earthing arrangements there?
That neutral block looks a bit weird, too.
I hope you used the no trip function on your meter so you did not trip any RCD in circuit
Looks like the gland for the SWA is sitting on top of the trunking Pic 3. the person who wired it must not of known what is was for don.t see any asbestos though they look like bs88 fuses for what its worth , and i think the earthing arrangement is yet to be arranged :)
Reply to Todays EICR gem - must be having one of those weeks in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
Recommended Sponsor News
Hi everyone,
