Discuss sub main started. in the UK Electrical Forum area at ElectriciansForums.net
just because its a waste doesn't mean I dont have to do it.
we have to follow a spec as well.
and I was only talking about swa in the short jump from trunking to panel anyway.
quite often we end up bushing directly into the panel and not through the gland plates so its perfectly acceptable (I would prefer the gland plates though)
I hope that piccie wasn't taken with your Canon 20D.
10D. yes it was. problem was the poor light level, and the fact that the autofocus could not settle because of the glass on the meter. after a few beers, the manual focussing was just as bad,
Nice camera Tel!!, I keep saying I'm going to splash out one day
only thing i don't like about the 10D is the small screen size. think the 30D has a bigger screen, there's a great camera shop in chester, 2nd hand SLRs at good prices.
no, not as in full 35mm, it's smaller. some later canons are full frame but not sure which. ask geordie, he's got a 30D or a 40D.Is it a Full frame Camera
Our lass has the very same although the SD card port is a bit worn and has a nasty crack at the rear.... :smilewinkgrin:Our lass has a couple of 36D. Lovely to handle and a doddle to use. Easy laid out functions with only 2 buttons to control and brilliant to zoom in on.
hope that's the camera that you are referring to.Our lass has the very same although the SD card port is a bit worn and has a nasty crack at the rear.... :smilewinkgrin:
Reply to sub main started. in the UK Electrical Forum area at ElectriciansForums.net
