sub main started. | Page 2 | on ElectriciansForums
Discuss sub main started. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
new sub as existing 3phase board is full. this is the job that glenn's with me on. just got the first 3 single phase circuits in. waiting for location of 3 phase supply before getting cable in.
[ElectriciansForums.net] sub main started.
This is why for the extra cost on these kind of installs, I bung in a length of 4" trunking, 2" bushed and earthed. Then I gland all my SWA's in, bolt through the banjo but no tail required.
Why fit a banjo when glanding onto galvanised trunking?
Personally I use earth nuts these days as they make good reliable contact whether it's bare metal or painted. I only connect a flylead with insulated enclosures or if I have any reason to doubt the earthing of the metal I'm glanding in to.
Gland plates I will run a flylead to the gland plate and sometimes replace it with a brass plate if I have a lot to make off to it.
Do you earth the armouring at both ends? I was told that you should because if you didnt and the unearthed end was terminated into an enclosure with other earths there could be a risk that they could be at a different potential.
OK ...i`m just going to come in at this point Dark..
Tel did mention about sticking a fly lead on them armoureds i glanded off into that panel....i said no...on the basis that its a steel enclosure....
so if theres any contravention here then i will stand and take fire for it....
It was only brought up because its a gland plate Glen and not the main solid steel enclosure so would require a tail earth regardless of the separate core, don't get me wrong there was no intent to sound like I was taking a pot shot at his work but that aside I admire your honesty :grin:
no i know that.
and yes...i should`v known better than to rely on a few self tappers for R2 on the armourings...
the reason i came in at that point was that i wanted to emphasize that it was me that made the decision to go without banjo & flying lead....
not Tel.
not always needed, I could show you pictures of a place that has that much steel bonded to the MET its a waste of copper to put on fly leads to MB.
we are talking about unistrut from window brackets on steel girders bolted to floor.
we get through a fair bit of unistrut. at least 50 x 3m lengths in this one room
Ooh...
think of the parrallel paths....
be a bit like `loop the loop`....
You're talking to someone who would be more than happy to carry on the old method of building a steel frame from steel angle welded together to carry the switchgear and busbar etc then bolting the incoming earth to the steel frame and everything else earths through the steelwork/trunking etc.
I've just started subbing for a company who had me installing 19core SWA to carry 6 circuits, I'll be having words about that waste of copper soon enough, 12core would have been fine!
I've seen the materials list for the next job too, 700mts of G/Y to pull in to steel trunking/conduit! I'll be buggered if im wasting my time doing that!
just because its a waste doesn't mean I dont have to do it.
we have to follow a spec as well.
and I was only talking about swa in the short jump from trunking to panel anyway.
quite often we end up bushing directly into the panel and not through the gland plates so its perfectly acceptable (I would prefer the gland plates though)
I know sometimes we have to follow a spec no matter how daft it may be.
Like why you have to use SWA for a short jump from a panel to trunking? Why don't they just join the trunking to the panel, or use conduit?
But hey, if they are putting their name to the design they can have whatever they want I guess.
I hope that piccie wasn't taken with your Canon 20D.
10D. yes it was. problem was the poor light level, and the fact that the autofocus could not settle because of the glass on the meter. after a few beers, the manual focussing was just as bad,
edit: bugger. wrong thread. was thinking of the pic of the meter. no. this pic was done with phone. with the phone in poor light, there's a delay between pressing the button and the phone actually taking the shot.
Nice camera Tel!!, I keep saying I'm going to splash out one day
only thing i don't like about the 10D is the small screen size. think the 30D has a bigger screen, there's a great camera shop in chester, 2nd hand SLRs at good prices.
Is it a Full frame Camera
Reply to sub main started. in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Who knows? There's this, in the OSG app H: "Permanently connected equipment should be locally protected by a fuse complying with BS 1362 of...
