0.5A difference between 2 identical inputs. Solarriver 4000TL-D
Update - after 2 visits each with a new version of the firmware Samil emailed me with a firmware upgrade which seems ot work. The 2 strings are now showing within a few watts under identical conditions. Apparently the issue was with the way the 2 strings were tracked.
