0.75mm Flex into 6A MCB | Page 3 | on ElectriciansForums
Discuss 0.75mm Flex into 6A MCB in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
As per title, how would you feel about connecting a few garage lights onto some 0.75mm flex straight into the 6A MCB, ignore switching, just that its 0.75mm.
I have to say I normally go via a FCU but in this occasion I don't feel I need to as its in the garage with a 6A MCB I can come off.
referring to table 4F3A on page 378 it states 0.75 can take 6A.
id say I'm good to go, I k ow I'm probably stating the obvious but it's not something I usually do, hooking such a small co doctor up to an MCB.
reason for it being small is due to the fact I'm using 3 core and earth flex so I can use the switched output on the lights so they Interconnect on PIR.
So with reference to my post #8, Am I wrong in my interpretation of table 52.3 ?
I understand that 521.9 applies which is what Davesparks is referring to, and I would never personally consider flex for fixed wiring, or less than 1mm live conductors for any fixed circuit, but the table does seem to support the OP's ideas.
It's a confusing grey area I say, I suppose, the bottom line to this is if the cable is suitably protected or not, I will reevaluate my usage of 0.75mm cable and use 1mm from now on.
as said, this is only to feed an outside light, I am not a silly billy wiring an entire light circuit up with it.
It's a strange one actually, Reg 422.3.201 says suitably protected against mechanical damage, but it's strange how it doesn't say a word about suitable protection if it's twin and earth which is just a different shape...
why should flex need any more protection than any other cable irrespective of the CSA of the conductors.
And different conductor construction, and insulation construction, and sheath construction.......
It's a fairly recent change in the regs which allowed flex to be installed at all, it was previously limited to 2 metres max length for appliance tails.
Every cable has to be suitably selected with regards to protection suitable for the environment it is in, regardless of what type it is.
Have you considered the max conductor operating temperature of the flex? A lot of it is rated to only 60degrees when fixed wiring and accessories are all rated for 70degrees. Will this make any difference? I don't know, but you need to consider it
Here's a bit of relevant history
14th edition
[ElectriciansForums.net] 0.75mm Flex into 6A MCB
13th edition
Reply to 0.75mm Flex into 6A MCB in the UK Electrical Forum area at ElectriciansForums.net
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
